Water pump
vt_lover
Gladstone Qld
vt acclaim
i have a noise like bearings on the way out, only when hot. i pulled the belt off and the water pump makes a noise when i turn it but doesn't feel bad, when running there is a grumble i can feel on the tension pulley. i just wanted to know if there is supposed to be any noise at all when turning the water pump by hand or is it supposed to be silent.
BOGANV8
I gotta V8 whoot whoot
41
Armidale
VX 02 SS LS1
I think its suppose to be silent noise means not good :ranting: :ranting:
how many klms has it done and is there any leaks from the water pump
vt_lover
Gladstone Qld
vt acclaim
There is no leaks but it has done 210000, original pump. should it need a new one?
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
If it's making a noise, replace it. Places like Repco and Supercheap sell them as well, usually a lot cheaper than Holden.
BOGANV8
41
Armidale
VX 02 SS LS1
sounds like it does that pretty high klms for the water pump
the other way to check is to use a screwdriver on the housing with your ear on the end of it and listen for the noise (just be careful of moving parts)
have a look on ebay for the water pumps the go pretty cheap
vt_lover
Gladstone Qld
vt acclaim
Thanks guys :thumbsup: , i did check the noise with a screwdriver and it was silent, but the tensioner pulley was grumbling, but if turned by hand the water pump makes noise:bang: :bang: if they are cheap i might just replace it anyway:thumbsup:
BOGANV8
41
Armidale
VX 02 SS LS1
i would do the tensioner pulley first then see what happens
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
It could just be the bearings in the tensioner pulley.
