Water sound from behind the dash
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vsdeath, Jun 4, 2009.
  1. vsdeath
    vsdeath New Member
    1995 VS Sedan
    Hi there,
    I have seen a while ago a post about someone hearing some water flowing behind the dashboard. And I cant find it anymore. Anyway, here I am... Go the same thing happening to me since a few weeks now.
    So if anyone can point me to that post or just tell me what it can be, that'd be good.
    Thanks a bunch.
  2. Fun_Bucket
    Fun_Bucket New Member
    Cairns White Rock
    Cruze II sri
    yeah mate i had the same issue, apprently it has somthing to do with the heater lines. I was told to open my radiator cap, and turn the ignition on and turn on the heater. Then to add coolant. I didnt turn the heater on, i just topped up my coolant both at the radiator and at the resivour. The niose stopped after this, and has only returned once the level of the coolant resivour began to get low again.
  3. FirstVR_JC
    FirstVR_JC New Member
    Cairns
    RALLIART Magna
    ^^^^ ahh another mystery solved for me due to the info sharing of this forum ..... I had been noticing the same thing, and just so happened i was losing coolant and needed a new radiotar .... now all that is fixed i dont hear it anymore.
    Always learning something new on here .... mind you i didnt know much to start with:p
  4. Fun_Bucket
    Cairns White Rock
    Cruze II sri
    funny i only started to get the noise after i had my radiator flushed.....
  5. vsdeath
    vsdeath New Member
    1995 VS Sedan
    Yeah actually I just changed my radiator lately. I'll try to bleed the cooling system again tomorrow.. Maybe there is some air trapped in there...
  6. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    When you bleed the system for air make sure the heater is turned to HOT otherwise the air will be trapped in the heater.
  7. ozyprd
    ozyprd want to know more
    ingleburn nsw
    vs senator
    thanks guys this site rocks u find out so much from this site will be doin this in the morning
  8. vsl67
    vsl67 Member
    VS l67 statesman
    Check the drian hole for the aircon is not blocked,its under the heater core, the only way to check it is get under the car and feel around for it above the gear box bell housing
