Ways to clear fault codes for my 2009 sv6 ve
Can it be done without a scan tool
  • Yes there is a way
    Votes: 0 0.0%
  • No not at all possible
    Votes: 2 100.0%
  • Total voters
Pauli1sv6
47
Newcastle
VESV6
Is it possible to clear fault codes manually without a scan tool or mechanic in my ve.
syked
Donating Member
2011 WM Caprice
Sometimes disconnecting the battery for an extended time might remove the check engine light
But this is only a cover up really because the fault code will still exist and the check engine light will still pop up again until the fault has been fixed.
timd29
VE Calais V S1 International 6.0
Just get a Bluetooth obdii unit for $30 on eBay. You can clear the fault and you also have something to read any future faults you get. Even cheaper ones then $30 I think
Fu Manchu
WA.
It is only able to be cleared using an OBD2 device with that feature.
mechanic
Australia
Commodore
Check Engine fault code - no. EOBD rules say that an emission-related fault code can only be cleared with a compatible scan tool, or through the car's own self-diagnostic mode.
Other system fault code - depends. There are no rules as such and some systems can be deleted by battery removal.
As others have mentioned, the fault code is present because there's a problem. Deleting the code only restarts the car's self-checking procedure, and the code will reappear once the fault is detected again.
Pauli1sv6
47
Newcastle
VESV6
Pauli1sv6
47
Newcastle
VESV6
Is there a specific type to get say if the engine doesn't start because the computer is still in limp mode.
Pauli1sv6
47
Newcastle
VESV6
Pauli1sv6
47
Newcastle
VESV6
The old engine the right bank timing chain jumped bending 6 inlet valves (right bank) replaced the engine that starts but doesn't keep running with petrol soaked rag in the through of the throttle body , been told that some Bluetooth scanning devices only work with the engine running, is any models you can suggest to Diogenos and clear fault codes.
timd29
