Depends on the herbicide. Many can become ineffective when you increase the dosage.actually it better practice to use a stronger herbicide than the cheaper ones most seem to use due to $.
The point is you use less poison that actually does the job and used less often over the cheaper non working ones that don:t have a huge range of effect on different weeds, hence you need more and more applications.
Wasn:t talking about dosage, instead the amount of active ingredient @grams per litre in the brand product you buy. Most people buy the cheaper brand product unaware of its strength and effectiveness, when it doesn:t work they stupidly increase the dosage thinking it will be stronger.Depends on the herbicide. Many can become ineffective when you increase the dosage.
Cheaper won’t mean doesn’t work. That’s a misconception. All products have to do what they say they will do by law. The problem isn’t the herbicide but often a lack of skill in applying them.
What cheapo roundup did you get?Turns out the cheapo roundup is doing its job. There are the beginnings of some yellowing, and plenty of droop, all over the backyard. May spray a bit more tomorrow if the weather is ok.
Yes apparently that is a problem with lots of men once they get to a certain age.
