br77
Hello guys,
Just want to get some ideas on how to set the correct height of the car using coilover / lowered spring.
Let's using an example (unusual case) here, if adults weigh 200kg sit at the back, adults weigh 140kg sit at the front, and also have 80kg loaded in the boot. What sort of clearance should be looking at assuming spring rate is 10?
I am thinking of 370mm center to guard distance on each wheel (20s) but unsure if the weight is going to be equally distribution to each spring.
Many thanks if somebody can educate me with suggestions.
