weird LS1 issue
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by GEN3RATD, Jun 8, 2011.
  1. GEN3RATD
    GEN3RATD 100% Teflon
    Cannington, WA
    VE Maloo
    hey guys,
    had a bit of an issue cruising to perth today, was sitting on about 90, and had my oil warning light pop up followed by the warning noise. looked down and noticed my powertrain warning light was on as well? as soon as the oil light warning tone had finished the light turned off. pulled over and checked the oil and it was all good, bit on the low side but still all good. as i drove it a bit more (few kms down the road) the oil warning light and powertrain warning light would flash erratically, not following a particular pattern.
    going to top it off on oil anyway, when i pick it up, was just curious as to why the powertrain warning light was flashing as well? its due for a service anyway so as soon as i can bring it back to mandurah ill book it in,
    cheers, dylan
  2. RIDE:42
    RIDE:42 crew chief
    vuss
    The sender unit at the back of the manifold has gone $90 at holden you have to lay across the engine to reach down the back and will need a 30/32 mm long reach socket to get the ####er out
  3. GEN3RATD
    Cannington, WA
    VE Maloo
    Ahh so I'm not in any danger of my car being damaged? Like I said I checked the oil, was low but was still in the ok part
  4. Vt_vic
    Vt_vic New Member
    perth,Western Australia
    carless for now
    if its your oil pressure sensor the powertrain light should come on only but go to a mechanic with a tech 2 and you find out in a matter of seconds and most mechanics wont charge you you use their tech 2
  5. GEN3RATD
    Cannington, WA
    VE Maloo
    both that and the oil pressure light are coming on, randomly. i checked the oil and it was fine?
    like i said i just want to know if i should be right to hobble it back from perth to mandurah, and then ill take it to ultratune.
  6. Vt_vic
    Vt_vic New Member
    carless for now
    since you are in perth just go to a mechanic and ask them to check it out quickly. when my oil pressure sensor went i drove it for about 6 months before i could be bothered fixing it but my powertrain light used to come on once every while
  7. GEN3RATD
    Cannington, WA
    VE Maloo
    yeah it comes on and off every now and then, its just the oil pressure light that bothers me a little, but at first i thought id dumped all my oil on the road.
    thanks for the help mate
  8. SirNemesis
    SirNemesis New Member
    Geelong, VIC
    WHII Statesman
  9. GEN3RATD
    Cannington, WA
    VE Maloo
    yeah mate thats why i said im just wondering if ill be cool to hobble it home, and then from there to the mechanic. ill be fixing it as quick as possible, was just wondering if it would be a bad idea to drive it all considering their is still oil in it and everything seems fine?
  10. SirNemesis
    Geelong, VIC
    WHII Statesman
  11. GEN3RATD
    Cannington, WA
    VE Maloo
    fair enough, ill be sure to get it fixed asap
  12. GEN3RATD
    Cannington, WA
    VE Maloo
    so has anyone got any ideas of what it could potentially be? im hoping it is just a faulty oil pressure sensor.
    im **** scared it could be low oil pressure or something, and im going to destroy my LS1.
    im thinking it might be worth driving it down the road to the mechanic once i pick it up and getting it scanned with a tech2, i get paranoid when things go wrong :/
  13. GEN3RATD
    Cannington, WA
    VE Maloo
    well sirnemisis you can say you know of an oil pressure switch failing with the oil light illuminated :)
  14. SirNemesis
    Geelong, VIC
    WHII Statesman
  15. GEN3RATD
    Cannington, WA
    VE Maloo
    so am i haha, i was worried for a bit
