Weird speed alert problem
tallman5353
2014 Karma VF Calais V6
Hi everyone,
I am experiencing this weird issue with the speed alert in my VYII Calais.
The speed alarm seems to come on at 63 or 64km/h when i have it set for 65. I activated the digital speedo in the police mode to confirm this.
The speedo needle also shows it is at/around 63/64km/h, so i don't think the speedo is out.
It also happens for all other speed alert settings too, ie: 85/105/115 etc.
Anyone have this issue? Kinda strange. A bit annoying too.
tallman5353
Hmm, i don't think that is the issue, when i cycle through police mode, the needle stays on 100 fine. I tried GPS'ing the speed and it is like most other cars, the indicated speed is a couple km'h over the true reading (normal).
I'm out of ideas, would a speed calibration via a tech2 fix it?
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
tallman, I think you'll find you are not alone and damn near every commodore out there does it. We just learn to deal with it.... Mines set for 150... So I rarely see it.
tallman5353
I still think there must be a way. All the dials work as they should, I just don't see why the speed alert is cutting in so early, I've never had this problem on any other car, and that includes a vt commy and a wh statesman.
What gives?
Tasmaniak
41
S.E. Melbourne
They use two different speed measuring systems.... it's not your speed alert thats out. Its your dash. You said that the dash reads a couple of k higher when verified with GPS? So if your doing 65 by the dash then the GPS will say 63~ correct? Which is the point that the speed alert kicks in.
tallman5353
No, it is the other way around, it is like most cars where the dash reads a higher speed than the true speed.
tallman5353
Actually wait, yea you were right.
How come on other cars the speed alert doesnt kick in early then? Is the analog and digital speed readout wrong?
tallman5353
Last time i tried the gps, it was dead on with what i was seeing on the dash. But the speed alert was still kicking in a 63/4 km/h
Will have to test again.
Tasmaniak
41
S.E. Melbourne
potentially... again, it's not uncommon. Especially if your speedo has been recalibrated by physically moving the dials, this obviously won't recalibrate the digital readouts. If it was calibrated with a different tyre size then what it has now... that'll throw it out again.
