weird vibration
kooee17
boat harbour
vu series 2 eco tech
ive got this weird vibration in my vu ute.
it only starts when the car gets to its normal temp,
or if i turn off the car then start again while at norm temp,
ive replaced the tailshaft center bearing thinking it was the problm but it didnt help the prob.
read a bit in the forum that it could be the ECU, played with it today still no good??????
Futech
Like a boss
50
Auckland, New Zealand
VY 5.7
Ahhhhhhhhhhhhhh how do you exactly play with the ECU..................
lout
60
Langwarrin Victoria
bit more info please
at idle?,
at certain speed?
in gear auto?
felt through steering wheel or brake pedal or seat of pants?
new problem or gradualy got worse?
kooee17
boat harbour
unpluged battery for 1 hr then went for a hard drive holding over 4000rpm for 5secs???? i read its spose to reset the ecu??? to tell u u truth i dont really have a clue with that stuff??????????
i reset the service counta and played with COPmode on the inboard stuff too. its pritty cool, find it on you tube.
kooee17
boat harbour
it starts the vibrating when its hot
stays while driving at all speeds and in idle
its a 5 speed manual
i can feel it coming from the engine
it just started doing it one day last week it dosent seem to be getting worse???
theres also abit of a delay in exceleration sometimes??????
could it be missfirering??????
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
ive had a look theyz all good ??????
Sometimes they can look fine but take some weight off them and it might be a different story. Jack the engine up a bit and see how they look then.
Rowenb
VP Calais
He changed leads and has fixed problem. The old ones he took off were half the dia of new ones and looked worse than what the factory would use.
