Weird 'whistle' type sound when the car is cold
TheDmac
Melbourne, VIC
VY SS
I have a 1999 VT Acclaim Series II. Recently the car has been making weird 'whistle' sounds when I first start it in the mornings. It seems to only happen when the car is cold. I recorded the sound this morning whilst I was cleaning frost off the windows.
VT by dfapskpro on SoundCloud - Hear the world
Has anyone else experienced this sound? It also makes the whistle sound when I accelerate, almost sounding like a fake 'fully sick' turbo type sound.
iaydemir
Donating Member
VY V6 Berlina
Stick your head in the engine bay and listen to where the noise is coming from?
Do you have a standard air filter/CAI?
I would say its your cold air intake.
evilholden
melb
vy berli a ser 2
check ur idler pulleys they play up more when it is cold
Cashman_309
VTII Calais
Sounds like pulleys to me. Take off your accessory belt and start the car, if the noise is gone, then you need to try track down the noisy pulley. Spin them by hand and replace the ones that rattle or wobble.
Cashman_309
VTII Calais
Should also say. Mad props for putting up a sound clip. Hate it when people make threads that start with 'my car make dis wierd noiz! hurrrr, halp me commo forums' and then never post a clip.
TheDmac
Melbourne, VIC
VY SS
Thanks for all the replies! I'll try a few of the suggestions and see how we go.
Haha cheers. Seemed almost impossible to adequately describe the sound so I decided record it :p
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
Sounds like the belt slipping to me. It could be an idler pulley starting to seize.
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Pulley or belt.
Easy way to determine, pour some water on the belt and of course out of the way from any electrical systems etc.
If it immediately goes quiet, belt maybe worn and check the tension of the belt as well
Could also be a pulley as well.
In my build thread, i took off and regreased 3 pulleys on my car and replaced another as completely sealed. (they got coolant in them and were a bit rough)
I had a metallic sound far worse then that, ended up being the belt had worn a bit and stretched and so replaced it and presto.
Jack92
Murwillumbah
Vt 50th anniversary
I have just noticed my car making a very similar noise from the intake only now that the mornings are getting colder why would this be?
