WH 2001 indicator arm
chip
VH SLE
Can anyone tell me if the WH and WH2 indicator arms are interchangeable? Holden only keep the VX round type now, ten pin.
Nut Kracker
Donating Member
65
Echuca Vic.
VT SS 304ci (195i)
I'd say they are interchangeable.
According to this one....VR,VS,VT VX Series 1 & WH INDICATOR STALK (WITH CRUISE) "ALL VR. VS, VT & VX SERIES 1 (SEDANS, STATESMANS, UTES & WAGONS)" must use 7 pin, I think.
So it stands to reason, that from the Series 2 on, they must have been 10 pin and the WH series must be 10 pin as well.
If yours is ten pin, then by all assumption, the VX one you are talking about, should fit..........Maybe.
Nut Kracker
Donating Member
65
Echuca Vic.
VT SS 304ci (195i)
Well....I did say "maybe".
But I'd say the WH and WH2 would be interchangeable.
chip
VH SLE
Cheers, I'll have to get one from GMH and fit it, all the functions worked ok oksa?
Sent from my iPad using Tapatalk
NSTG8R
SA
HSV Maloo R8 + VX Berlina 5.7
they wont work without mods...WH Series 2 use the same stalks as VX Series 2, WH Series 1 and VX Series 1 use the earlier style stalk.
If you can't buy one new then wreckers would be your best bet otherwise you'll have to modify your wiring to run the Series 2 stalks
chip
VH SLE
CBF donin all that!
I'll look around.
Sent from my GT-I9100 using Tapatalk
chip
VH SLE
Only problem is I need ten pin plug.
Thx for the help anyway.
chip
VH SLE
I'll give em a ring and see if they have ten piners!
