ChrisD12
Hi Guys,
I hope someone can help me with this little problem. I have already placed a Hi/Lo HID H4's in the main headlights and they are working great. The problem I have is with the High Beam Spots, I have purchased the same brand of light and they are to be plug and play as the H4's were but NO! When plugged in as per wiring diagram they do not work. I have tried swapping the wires (I was very reluctant to try that) still the same result. Then tried a test light on the two female heads to find both live when the headlight switch is in the off position. I suspect the H4 package's controller is having some sort of impact on the high beam switching. I can confirm both lights work when connected directly to the battery still...
Your assistance will be greatly appreciated.
Cheers Chris
Cheers Chris
