VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,273
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
Right!!!!!maybe a loose or bad connector.
After reading the internet with this issue for up and down revs at idle and after reading this and other sites https://www.motor.com/magazine-summary/lean-codes-january-2018/ I have become desperate looking for possible bad connection so I found the ECU/PCM and any socket that can be uncliped and I uncliped it. Started the car NO GOOD It still was idling at 1100, 1200,1400, fu..kkkk. I restate the car again (1200 RPM)and this time rattled the 3 connectors behind the the power booster and the car was the same then I rattled the IAC wiring and it was the same and the last thing i touched was the TPS wiring harness and the Revs went from 1200 to 1400 to 1000 to 900 to 1400 so after seeing this I stopped the engine and took the connector off as the TPS is new and should have no corrosion (Male Pin) in it but looked into the socket (Female connectors) they look (3 of them) like to be spread out so I got my contact cleaner and small surgical screw driver set and pried in the 4 side on the three female connectors gave them the contact cleaner and re connected the connector and I noticed it has slightly harder to get in.
Now I disconnected the battery and left it off for 30 seconds, re connected the battery and started the car and the Idle was around 1000 RPM than after 3 seconds it went to around 950 RPM.
I took the car for a drive for 35 minutes and I hammer the car with stops and starts noted the idle and putting the car in neutral when stopped then when I can put it park and it Idles Perfect!!! I tried to trick it but still Idles at 950 RPM so after this test I went home and let the car rest. 4 hours later at night I did the same and took the car for 15 min drive and it was perfect. Now that was yesterday
Today I did the same I started the car first thing this Morning (8 am) and the car started at 1200 RPM than second later it was 1050 RPM, minutes later it was 950 RPM and I went for another 15 Minute drive and done the same test by stopping the car, putting in neutral, also in park and noted the idle also I noted the rev whilst the car was in drive PERFECT!!! . Drove the car home and it perfect and I hope it stays this way.
If this was the issue with a bad connecting connector on the Throttle Position Sensor (TPS) no doubt the extra revs was being done by the IAC Valve allowing more air via a fake voltage on the TPS.
I will re test this car for the next 3 to 4 days before I give it back to my Son.
