WH Statesman Heater and Air Conditioning Fans Not Working
Brysha89
34
Melton,Victoria
WM Statesman L98 6.0ltr
Hello again JC Member's & Guest's as My Thread Head says my Fans for heating and cooling the inside of my car are not working i have changed the fuse to the whole heating control and still nothing. What am i Looking At Price wise as it's going to be beyond my capability's?
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
There is only one fan and I bought one recently from Holden and it was about $300 if my memory serves me correctly. First you should remove the fan assembly and check it to see if it is in fact stuffed. Sometimes a good clean can get them going again. Mine was still working but a little rusty in places and the bearings weren't too good either. When you pull the fan out connect it to 12 volts and see if it works, if it does you might have a wiring problem. Also check the blower relay first.
BlackVXGTS
Melbourne, SE
Do the fans not work on any speed setting, or do they only work on the highest speed setting. The highest speed setting works directly off the fan relay. The other speeds work off a fan amplifier which gives the variable speeds. The fan amplifier can be repaired/replaced quite cheaply, and removal/installation is also very easy.
Brysha89
34
Melton,Victoria
it dose not operate at all, light's come on settings can be set i.e. air con, heater outside temp but no fans to push the air out of the vent's.
Brysha89
34
Melton,Victoria
accentstencil i would not have a clue where to find that i'm no mechanic and no auto elec but refuse to go to one as i have been ripped off 5 times in my area so i do my own repairs and services now, and i have never touched wiring on a car be for besides changing a battery terminal, hence the reason for asking how much to get it done by one so i can tell what ever crap mechanic in my area how much it should cost so they don't rip me off. but if its an easy job could you point me to how i get to the fan?
Brysha89
34
Melton,Victoria
I also brought Rear Shocks for my statesman at Auto Barn Yesterday when asking for them i was asked by the person who served me if it had self leveling shocks im prity sure sires 1 Gen 3's had the standard and sires 2 WH's like you're one accentstencil had the self leveling shocks yer?
accentstencil
71
Mine didn't come with Level Ride, I installed it myself.
If you have it you will hear the compressor cut in soon after starting the car (unless it isn't working) it's pretty loud so you would hear it.
There would also be a relay in the fuse panel in the engine bay, I have marked it in red in the picture.
The compressor would be up above the driveshaft on the passenger side.
accentstencil
71
Believe it or not, removing the blower is quite easy. You remove the plastic cover below the glovebox in the foot well, I think it just clips into place.
Then I think it's just a matter of undoing 3 screws that hold the blower assembly in place, undo the electrical connector and maneuver it out.
Theoretically it should not cost a lot because it doesn't take long but you never know.
Brysha89
34
Melton,Victoria
Tyvm accentstencil for the info ill have a look today at the fuses in the engine bay see if that fuse is there and and see if i can pull the blower out to test if its that hopefully it is and not a wiring problem
53
2000 l67 commodore berlina
do u mean the climate fan control fans r not working in the cabin ie when u turn the fan on if the car r u or r u not getting any air blowing through the vents? if not i can tell u how to fix this!
