2O4TS
As some of you may know, a couple months ago I did a climate conversion on my VT and installed a WH Stato body loom.
After some minor teething problems I got it driveable pretty quickly however I do still have one minor issue to deal with.
The fuel pump wiring on the Stato loom differed from the Commy loom. Some help from a couple of posters and a bit of tracing and testing and that was solved so I got it running.
However what I didn't sort out was the fuel gauge wires.
The Commodore (L67) had a four pin plug but the Stato had a 5 wire plug that looks like this:
So the Black/Blue trace and the Violet (outsides) are the fuel pump earth and 12v, no issues there. Can anyone tell me specifically which two of the three remaining wires (Black/White, Violet/White, Light Blue) are the wires that run to the in tank fuel gauge (potentiometer)? If possible too (though less urgent) what the remaining wire is for. My guess is it's something to do with the fuel controller which I don't currently have installed but will be eventually.
The wiring diagrams I have as you can see show the colours of the wires but don't tell me specifically which wire is for what.
Thanks in advance.
Thanks in advance.
