WH Wheel alignment specs
alby1976
South Australia
WH Grange Gen3, VF Calais V Wagon, VY Calais L67
Hey guys.
I have a 2000 WH Grange, does anyone know what the wheel alignment specs are? or have a sheet that I can print out.
Every time I get a wheel alignment, it seems I have a different car, yesterday it was a WL Statesman with FE2, and they didn't even do the rear wheels, then I pointed out that it had 4 point adjustable bushes fitted, so I have to go back, but would like the correct specs for them to aim at.
BlackVXGTS
Melbourne, SE
From the Holden Service CD:
The toe-in specification is deliberately quoted as an angle because wherever possible toe-in should be measured in degrees. Refer below for the recommended wheel alignment settings. These settings are at curb weight, which is the vehicle
in a condition of full fluids, full fuel, no people or luggage.
Front Toe-in Degrees Total 0°10' ± 0°10'
Degrees Per Wheel 0°05' ± 0°5'
Camber – 0°30' ± 0°20'
Caster 7°45' ± 1°15'
Rear Toe : 0 ± 1mm (0°± 0º10mins)
Camber : -1°30mins to -2°30mins
Torque Settings : 65 ± 5Nm
