H
harrop.senator
Guest
So I've just received the notification that the 3d printed console mount gauge cluster will arrive today.
So I've got two surrounding my steering wheel built into my fascia.
Up here I know I definitely want an afr guage. The second gauge I'm unsure between , boost, oil pressure or oil temperature.
The other 3 are down under the stereo so it needs to be less important casual glance gauges.
Set up is a manual a2a cooled , cammed and flex fuel l67 with an LS1 pcm and map based.
Oil pressure is very important but apart from cutting it off a lot of the time can be to late if have a big issue quick.
Oil temperature can show me if I may run into a pressure issue as I've cooked the oil and it needs to be shut off.
Boost I don't think will be that important as I'm not running a maf so can't lead to a big issue?
I think all up the 5 I want Afr , boost , oil press , oil temp and water temp.
I don't think I really need an ethanol percentage gauge it'll just be extra wank. I've not got variable boost like a turbo with a controller I've just got dual spark tables.
What would you run , where would you run them?
