richrever
- Feb 18, 2017
- 121
- 19
- 18
- Age
- 57
- Location
- Perve Western Australia
- Vs S2 V6 5,Speed Ute
Hi i just got myself a VS MANUAL UTE 1996 SERIES2 V6. Now the workshop manual tells me that all VSs come with the same gearbox (rpo m78) and that they dont have linkages? Well mine does! A mate thinks its a getrag? Can anyone comfirm this? Also my workshop manual mentions nothing about the rubber coupling/unijoint on the drive shaft just behind the gearbox. Im in the processe of replacing the center bearing and would like to know if i unbolt the shaft from the rubber joint (and not worry about losing oil) or if i slide the shaft out of the box and if so what can i use to block the box seal(will a auto drive shaft front fit)? Oh and one last thing... seeing as this gearbox is not the one in the manual what gear box oil does it use and how much ?
Cheers Rich.
Cheers Rich.
