What are these clips called ?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VS 5.0, Dec 19, 2013.
  1. VS 5.0
    Hi All,
    Hoping someone can tell me what these clips are called.
    Thanks
  2. mpower
    mpower Well-Known Member
    RADIATOR SHROUD TO FR PANEL CLIP, or something similar
  3. two-bit
    two-bit old enough to mang better
    VS S series II
    x-mas tree clips, pick them up from super cheap.
    no idea what gm call them.
  4. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    They are called different things by different people, scrivets, plastic blind rivets, *insert body part here* retainer, push type rivet. They will usually have a size associated with them pertaining to the hole they fit into.
  5. davway
    davway New Member
    Warrnambool
    WK LS1 Statesman
    They are called Scrivets.
  6. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
    Scrivets ...
  7. VS 5.0
    Thanks for the replies.
  8. Big-Al
    Big-Al Banned
    Aussie and proud
    VY SS 5.7 M6
    The ones supercheap stock are too small. Tried them before.
  9. VS 5.0
    I couldn't find any suitable ones online anywhere so I went to the local Holden dealer this morning with the shroud which helped the parts guy find the correct ones using the shroud's part no. He was probably the friendliest / most helpful parts guy I have come across in a while. They didn't have any in stock (apparently there are only 15 of them in the state) so he has ordered four for me and will have them in on Monday.
  10. VS 5.0
    Just to update...I picked these up on Friday. Holden call them Retainers. Part No. GM-92136489
  11. VS-S
    Couldn't you have just gone to Bunnings?
  12. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Yeah, GM were always very original with their part names. It's always good to have the part number - it's amazing how many different versions of "scrivet" the manufacturers have come up with. And the bastards never seem to be interchangeable.....
  13. Pollushon
    Pollushon Boost gives me a bar....
    VY SS
    Autobarn sell the exact right ones on their rotating fastener displays, $3.50 for four. I've had to replace a few lately.
    They are known generally as a push pin retainer, scrivets are the nickname given to their screw type counterparts, aka screw pin retainer.
  14. B-Man
    B-Man Member
    SA
    VY Calais S2
    i find ford styled ones fit better and look nicer (get them from crash supplies or wurth)
