What dba brake rotors do I need?
Juice3
Australia
VX
Ok so I know i need DBA040E for the front but what about the rear? the dba doesn't show anything for the rear on their website Holden vx berlina 2002
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
DBA041 is the part number for the rear rotors.
DBA041E is the part number for the rotor with the enshield coating........Basically it's a coating to stop the rotor surface from rusting
Juice3
Australia
VX
Yeah thanks I just got my rotors today and was worried I ordered the wrong rear ones because I was looking at another website and it said dba041E doesn't fit the vx 2002
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
Good choice, we've had ours fitted for 5 years and often tow a camper trailer. Sure I've replaced the pads a couple of times but the rotors themselves are still in great condition.
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
That website has definitely got it wrong, I have had 3 different styles of DBA040 & DBA041 rotors on a VX Sedan, VY Ute & VZ 1 Tonner.
For what it's worth:
All VT-VZ Commodores with the factory standard size brake package use the same rotors & brake pads.
DBA Rotors
DBA040......Front
DBA041...... Rear
Bendix Brake Pads
DB1331......Front
DB1332......Rear
There are obviously other manufacturers of aftermarket brake parts, but these would probably be the most common replacements.
