Rug Doctored the interior, then chucked some preen carpet cleaner on it and will rug doctor it again later Sent from my HTC Aria using Tapatalk II
Today: Serpentine belt, charger belt, eagle 10.5mm leads, iridium plugs, air filter, oil and filter, cleaned the maf and intake tube annnd new air filter. Tomorrow: swap driver and passenger seat around (seat pad is buggered), bleed brakes and replace fluid annnd attempt the fuel filter and see what the struggle is about......
My fuel filter was a Lil Biatch to get off even with the expensive removal piece of plastic to get it off. However persistence paid off. Sent from my HTC Aria using Tapatalk II
Replaced the blower fan resistor that stopped working last week, pick up a new one for 25 - not 80 from GM ..yes I know the GM one has a circuit & a heatsink but this one definably does the job very well, much better construction than the original. Whilst everything was apart I insulated the air con pipes under the "Over Wiper Motor Cowl" to stop the resonating gnomes with piccolos that would play non intermittent whistles through the dash when A/C was on - all fixed. No more weird whistling/howling noises & blower fan speeds 1+2 are now in full effect! Always disconnect negative battery terminal! Removing those little clips that affix the Cowl with a trim remover tool Old Blower resistor Old blower resistor - see the broken coil Old Resistor with dust cover off Old Resistor with dust cover off & Plastic cap removed New Blower Resistor Cleaned out under the Cowl, there was a descent amount of compost under there! Uninsulated A/C pipes under Cowl Started to insulate A/C pipes under Cowl, applied more formshield but this was the start Full insulation of A/C pipes to stop resonation whistle sound Job 100% done, wipers replaced I fully restored the Cowl & weather strip before re fitting Uninsulated & Insulated A/C pipes under Cowl also shows dust cover for blower resistor New blower resistor fitted Job done, just had to fit wipers If it's worth doing it's worth doing right :boxing:
yesterday put about 300mls of oil in it. either has a leak or it just started using a little bit. shall keep an eye on it. thought about fixing central locking on drivers door. didnt go ahead with it
Today the Calais got a nice wash and detail. Then I took her for a drive to the petrol station, filled her up and chucked in some injector cleaner as she has been running dry for the last 3 tanks (never again after I replaced the fuel pump :s) Sent from my GT-I9100 using Tapatalk 2
Installed a tranny cooler and a VS V6 Thermo fan into the VQ stato Was suprised to find the 2nd hand foam tune i bought controls the thermo fan, saved me putting in a thermal switch Picked up a set of VK Calais Leather seats for the VB Bought z-bar bushes for the Stato, yet to fit them in.....
Noticed my exhaust hitting on the chassis of the car - bent up a window frame and jammed it in between the two. There, I fixed it!
