What does one need to view error codes from the car computer?
pengoau
VS3 Commodore Ute
G'day
What equipment do I need to connect to my car's computer?
I have a '99 VS 3 Commodore Ute and would like to see what codes are being returned, as I'm having a problem with the engine dying while I'm driving it. So want to see if its saying anything about the CAS.
I take it I'd need a laptop and a data cable (what sort of cable? serial? usb? propietary?).
Thanks
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
you can just use a paperclip to get error codes but if you actually want to monitor ecu data with a laptop you need an aldl cable which are easy to make you need the 2 trans 8192 baud aldl cable.they work with either laptop with serial port or a usb to serial cable .the plans are on the net if you cant find it ill add an attachment of a schematic
pengoau
VS3 Commodore Ute
whereabouts on a vs3 is the computer port? You said I can use a paper clip, is there a built in lcd that'll show codes?
I'm just after diag/error codes so I can look em up to see if it will explain the problem I'm having.
thanks
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
heres a schematic if you want to monitor whats going on with a laptop.there has been debate over wether the diode goes that way round or the other way so if it doesnt work reverse the diode
pengoau
VS3 Commodore Ute
thanks mate but i have nfi on electronics, electrical wiring. So I'd need to purchase a cable if I ever need one.
Where's the computer port? Is there a built in screen for me to read codes?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
read the thread vn6pwr provided a link to above it explains everything you need to count the flashes on the check engine light to get the codes when you have the paper clip in the plug under the steering wheel
