What is a 14C supercharger?
losh1971
North Tas
VE Series I SS Ute
As above. Also is it worth $800 if it needs new gaskets?
Hivisibility
Casino NSW
VZ Cross8/VE SS L98 /Daily Ford BF XR6
It's commonly found on little Toyota Engines from memory... sort a bit small for a 3.8 petrol engine... may give a little more in the low and middle... but not enough to justify the costs...L67 is far easier and straightfoward.
losh1971
North Tas
VE Series I SS Ute
L67 would be a whole engine swap plus trans, PCM, k frame, loom and anything else required to upgrade. Simple bolt on would be a lot easier.
I appreciate the info though. It's not worth mucking around if its a small SC, which will do little. Bang for buck it sounds a waste.
gtrboyy
vt ss & lc gtr
They barely had enough puff for a 202 even then they had to be turned hard to get 4psi of hot air.
l67 swap or turbo the buick if you want forced induction.
vc commodore
Like the Leyland Brothers
VC, VH and VY
I paid $350 about 4 years ago for a recoed SC14 supercharger.....So $800, he's dreaming....
woteva
NEED 4 SPEED
Adelaide S.A.
Search for SC14 and you will find plenty info
losh1971
North Tas
VE Series I SS Ute
Interesting, because that's the first thing I did when I saw it on FB. I couldn't find anything.
_R_J_K_
Zenki S14
Not really, it's an Ecotec with a supercharger, so no k-frame swap, no PCM swap (you just need a memcal, and vs ECUs are cheap anyway), loom can be extended (although you are right it would be better to get the loom), gearbox is exactly the same as the regular V6 ones. Really you only need the engine. They came factory in the VS so it would be fine to use VS running gear, no linking necessary etc...
I think the SC14 is roughly the same size as an M90 (SC14 = 1.4L, M90 = 90cu), but the M90 is better in this application. To give you come perspective, Toyota put these on 4AGZE 1.6L engines, so why somebody got the idea to put a single one of these on a 3.8 is kinda beyond me. There's a couple of other downsides - some of the bearings cannot be bought new (genuine or aftermarket) and then there's the cost of tuning.
They're really sought after these days (dunno why), seems to be the standard price now. Probably because they were on old 86s or something or people trying to do suuuuper budget supercharger installs.
losh1971
North Tas
VE Series I SS Ute
I didn't think an Eco was a straight swap with a Buick.
I have a really decent Buick and fitting an unknown cond SC engine would be a risk.
losh1971
North Tas
VE Series I SS Ute
Found info on the Toyota SC and it will cause more problems than its worth it would seem. Plus they tend to detonate if you try and get any decent boost.
