What is needed to go from SSV to SSVR Brembo brakes?
Discussion in 'VF Holden Commodore (2013 - 2017)' started by woooo, Jul 29, 2017.
  1. VS 5.0
    VZ57SSZ likes this.
  2. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    Brembos under 18”
    (de-burred)
    Brembos under 19” VE SSV
    (Eibach TÜV adaptors)
  3. VZ57SSZ
    VZ57SSZ Member
    Central Coast
    MY16 VF Series II SSV
    Thanks I might re consider it now
    I
  4. woooo
    woooo Active Member
    Australia
    Multiple
    Lorem ipsum dolor sit amet, consectetur adipiscing elit. Cras ac nibh id felis accumsan placerat. Vestibulum fringilla massa vitae mauris malesuada egestas. Phasellus in nisi mauris. Phasellus posuere diam sed enim vehicula, at sollicitudin eros dignissim. In quis viverra lorem. Integer interdum quam vel massa congue ullamcorper. Donec hendrerit et purus in malesuada.
  5. monstar
    Peugeot 207 GTi
    You won’t get cheaper than that but only couple of hundgy more on eBay. Amazon Prime is like Costco membership, very efficient and quick worthwhile if you shop online, this deal would pay for itself and still save.
    Yes I got CTS-V brembos all 4 pistons ea, was the first here about four years ago. Now done 180k km on front rotors looking to switch up to the front combo I quoted above. Coz looks really.
    That includes everything, best DBA rotors 370mm per CTS-V.
    Regarding piston displacement vs master cylinder there has been raised several times over the years, it is the same master cylinder used SS & ZL1.
  6. woooo
    woooo Active Member
    Australia
    Multiple
    Fusce a ornare cursus mi sollicitudin lacus eros luctus dictum, ornare consectetur nisl tellus imperdiet hac ullamcorper ornare quam etiam, habitant habitasse quam viverra aliquam aenean fames laoreet tincidunt nec a nisl id aenean etiam pharetra adipiscing hendrerit mauris.
  7. monstar
    Peugeot 207 GTi
    IMG_2275.JPG No spacers, SSVR Alcoa drop forged.
    Never ever think about buying HSV brakes again. Google that, better still speak to Matt or Greg at Race Brakes / GSL Rallysport the forum sponsor.
    They really provide good advice.
    426Cuda likes this.
  8. woooo
    woooo Active Member
    Australia
    Multiple
    Lectus suspendisse eget feugiat hendrerit morbi dictumst facilisis senectus pretium, adipiscing diam lacinia urna aenean habitant vehicula dolor.
  9. RED LION
    RED LION Active Member
    SA
    VFII Calais V Sportswagon LS3
    Am I right in saying the CTS-V brakes are the same as the Camaro brakes?
  10. monstar
    Peugeot 207 GTi
    Basically, yes. They are mounted differently on the CTS-V so you need to swap the bleed and pipe around, the plus though is that one of the rear pistons are larger than the other, forget what that’s called, but means correct application of the pad to rotor. More effective and no squealing.
    Camaro rear rotors are different means no handbrake maybe same with CT-V, also different length hydraulic lines.
    Best to speak with GSL for more detail. You don’t need steel braid really.
  11. monstar
    Peugeot 207 GTi
    Camaro wheels, diff and the rear sub frame, CTS-V wheels, Z28 intake, headers and brakes. Variable Valve timing from the Camaro L99, rest is cosmetic.
    426Cuda likes this.
  12. woooo
    woooo Active Member
    Australia
    Multiple
    Himenaeos duis sed pellentesque ligula nec donec nostra aliquam, adipiscing sollicitudin quisque lacus quam eget curabitur, ullamcorper duis ac leo amet velit blandit.
  13. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Good question. I suspect the answer is yes. An engineers cert will be required.
  14. Forg
    Forg Well-Known Member
    Regal Peackock VF SS-V Redline Wagoon
    To the letter of the law, if you use a full HSV system you won't need a certificate but if you use parts from elsewhere in the GM world but not available for a Commodore you do need a certificate.
    It's one of those things where ... I couldn't suggest someone else bend the rules, but I'd kinda consider doing it.
    SuckSqueezeBangBlow likes this.
  15. monstar
    Peugeot 207 GTi
    So you think TMR considers HSV and Holden interchangeable but Chevrolet and Holden not?!
    HSV in this regard is another manufacturer altogether, so six pistons need a cert. :confused:
  16. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    Fair point
  17. Forg
    I don't know anything about Tommi Mäkinen Racing, but the NSW RMS most definitely considers an HSV Commodore to be "a Commodore" in terms of mods & the requirement for an engineering certificate, ie. the widest factory wheels fitted to a model, the largest-capacity & highest-power engine, yadda yadda.
    woooo likes this.
  18. monstar
    Peugeot 207 GTi
    OK I’ll just refer them to this post then. Thanks.
  19. Forg
    You could also refer them to themselves, it's probably a lot less effort than going to that post which goes back to themselves. :)
  20. monstar
    Peugeot 207 GTi
    Transport and Main Roads Queensland, is as different to Roads and Maritime Authority New South Wales as HSV is to Holden.
    When I get busted for faking an HSV in QLD I don’t think referring TMR inspectors to RMS is easier or weighs more than pointing the finger at you and your online guidance.
