What is the point of bigger rims?
Jarp
Surely You Jest
VFII SSV A6 W375
To what was said above I would also include extra weight to the vehicle as well, not by much but it would be more than what you started with. At this point in time I am deciding on whether if I should go to 20" rims just purely because that the stock 18's seem too small on the car (maybe its just me). Also debating whether I should just just lower it as is but I am yet to see a sv6 lowered with the standard wheels. Looking at pedders, either sports ryders or ssl's.
Just about to find out about lowering the SV6 on stock 18's so we'll see ey....I'm gonna keep the same rake though.
TinSnips
Polish all the things...
Hills District, Sydney
www.drivencolour.com.au
VF SSV Ute
Yeah its amazing what a difference some camber makes. I keep going to put her on the aligner and put it back to factory specs then I go for a drive through some twistys and decide against it haha.
You're right. That's when it all makes sense.
The fun in skids seems to have passed me by aswell. I'd much rather have my car set up so I can push it hard through the fun stuff and not die.
How much camber did you dial in, ricey? If be guessing it's a bit!
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
How much camber did you dial in, ricey? If be guessing upwards of 1.5 degrees!
Around 2.5 degrees from memory, cant go a lot more without modifying the strut.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
I don't see the point in these huge rims with jack-all rubber between them and the road.
My stepson hit a pot hole with these 20" rims or there-abouts, smashed two rims and sent him into the ditch. Rougher ride as well, with these bloody things. Nope I'll stick to my 225/50/16's.
I'm with you ^^ on that score. 225/50/16 have a nice road feel with plenty of rubber on the road and dont cost the earth to replace. No tram lining either.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
you cant beat a 15" wheel and tyre combo its been proven so many times on handling its not funny it may not feal as stable but will go round sharper corners faster do to the sidewall flex even straight line traction is way better i never go bigger than 15's.
RiCeY
Australia
Tram lining has nothing to do with low profile tyres
RiCeY
Australia
Maybe you should inform the V8 supercar teams of this so they can stop running low profile tyres, go back to 15s and then corner faster.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Wide tyres - it is tho. 225 on a Commodore is a good fit on the 16x7 rims.
RiCeY
Australia
Its caused by alignment issues or flogged out suspension components. I run 245s and have never experienced tramlining.
TinSnips
VF SSV Ute
Oooo that would make it stick! Remind me never to get in your way through twisty stuff... If I'm ever in WA!
Never had a single instance of tramlining with my 245s.
