What is this? VE Series 2.
Discussion in 'Electrical Wiring / Questions' started by boomer03, Apr 11, 2019.
Tags:
  1. boomer03
    boomer03 Dolphin Trainer
    VE SSV 6.0 Manual
    Hi all. Just bought a 2010 VE SSV 6 SPD manual. Loving it. I was under the dash today, looking to see if the GPS module was there. It wasn't.
    Anyways, while I was there I found what looks like an after market wire heading to the drivers side of the head unit. I followed it away and the closest I could get was that it runs along under the dash and disappears somewhere near your right knee.
    It's labelled PJ with some white DYMO label. The car is a series 1 but was fitted with a series 2 head unit by Holden when bought new (through a third party installer). That's about all I know. I'm thinking it may be something to do with the install?
    I've googled my butt off but can't find anything.
    Pics below. Thanks in advance
  2. Aussie Trev
    Aussie Trev Member
    Queensland
    2 by VX Acclaim Wagon Series II 2001 & 2002
    Is there a multi CD player or sub woofer amp in the system because it looks like shielded audio cable to me from the photo.
  3. Lex
    Lex Active Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    Input for reverse camera?
  4. VDO
    VDO New Member
    VB VC VH VK VL
    I believe that's for Video input. Either a DVD stacker or most likely rear camera.
  5. Aussie Trev
    Aussie Trev Member
    Queensland
    If you search for the make and model of head unit you will probably find a manual for it on line and be able to see what the input is for.
  6. Gotta_Drive_1
    Gotta_Drive_1 Member
    2010 HSV Clubsport R8 LS3 E3
    Looks like it is the cable already installed as part of the wiring loom depending on order for IQ with sat nav or not. I think if it has sat nav that plug actually plugs into a piggy back unit that sits outside the main unit.
  7. boomer03
    VE SSV 6.0 Manual
    Thanks all. After your tips I had a squiz at the reversing camera. Yep, that's it. I was really hoping for something like ASIO bug or similar though.
    Thanks again.
