What kind of oil ect... Do i use for my 1995 vs executive
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by x 2FACIN8 x, Mar 20, 2013.
  1. x 2FACIN8 x
    x 2FACIN8 x New Member
    bateau bay
    95 vs excutive / 98 hyundai excel twincam
    Hey peeps i didnt get a book with my car :( its a 1995 vs executive and i need to know all the oils and stuff i need to get for service.
    What kind of motor oil do i need ??
    What kind of tranny oil ??
    What kind of coolant ??
    And how do u tell if your lpg gas is in date ????
  2. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    Oil is 20W-50 in the book for a VS I believe. But I used 10W-40 Synthetic when my engine was younger and thats fine to use. Just use decent oil changed regularly. Trans fluid I think is Dextron III. For Coolant I use nulon, but just check on the coolant manufacturers websites for which coolants are compatible . And your Gas tank will have a date stamped on it somewhere
  3. x 2FACIN8 x
    bateau bay
    Sweet thanks heaps man :)
    My gas tank only has the date it was last inspected wich was 07 :/
  4. K-BAGZ
    K-BAGZ De Plane! De Plane!
    Far North QLD
    VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
    Engine: 20W-50
    Transmission: Auto - DIII. Manual - 75W-90
    Coolant: Green ELC
    Differential: Non LSD - 85W-90. LSD - Any LSD oil of your choice.
    Powersteering: DIII
    Brake and clutch fluid: Dot 4/Super Dot 4.
    LPG as stated above.
  5. yoshi87
    yoshi87 New Member
    south australia
    vs commodore
    if its not dated on tank then there should be a compliance plate on the front by the bonnet clip, it should have wat date the tank was manufactured, date it was fitted
  6. x 2FACIN8 x
    bateau bay
    thanks heaps :)
    do you know how much oil it all takes ??
  7. x 2FACIN8 x
    bateau bay
    thanks man :)
    do u know how much oil it all takes ???
  8. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    Mine takes about 4.2lt of oil normally
  9. VS_Pete
    4lt here I`ve always put that amount in. Book says 4.3lt with oil filter.
    Mine was always spot on the oil gauge.
    Just remember some had a deep pans so more oil needed.
  10. mudfish
    mudfish New Member
    nsw
    vs acclaim
    Automotive LPG tanks have to be tested and certified every 10 years. If yours was last done in 2007 it's all smiles until 2017.
  11. x 2FACIN8 x
    bateau bay
    Sweet was kinda worried bout the LPG noot now XD
  12. x 2FACIN8 x
    bateau bay
    Ill probs start at 4L and then just top it up :) cheers man
  13. VS_Pete
    When I first got the VS did oil change and drove to work next day level ground checked oil level in the afternoon when cold spot on the dip stick.
