What mods are needed internally for 5psi on a buick engine?
slappedvr
vr executive
hey guys
im looking at getting a sc14 supercharger for my vr v6 commodore.
its done 240,000 kms and was just wondering if i would need to change anything if i was to run just 5psi?
injectors/fuel pump?
also will the buick engine withstand 5psi?
and will i need a tune?
cheers
nick_
VY II V6
You've pretty much answered your own questions.
You will need a better fuel pump and higher flowing injectors
A intank walbro pump and L67 injectors will do for low boost.
Buick v6's are quite resilient to boost provided that all the necessary support systems are in place such a good fuel system, spot on tune, regular maintenance.
If you're planning on doing any decent skids/burnouts, etc than you will need a fully functioning upgraded cooling system.
Hope that helps.
Krisp
perth
D22 St-r Navara
sc14 is alright for the buick on low boost. just bolt on and drive
Reaper
Tells it like it is.
You will need a tune at the very least.
Reaper
Bz Kn33z
Mildura
Black VN V6 Turbo
5psi your still gonna blow head gaskets, i ran a 5psi pulley on a sc14 unintercooled, with a foam tune and blue top injectors and ran quiet well, made 154rwkw on 4.8psi also took the heads off to put on some other ones, and there was no sign or damage done to the felpro gaskets i had on there.
19psivt
Vt L67 intercooled supercharged
bolt it on if it blows get another $200 engine... Its not worth doing any mods for 5psi
GothicKidd
ლ(ಠ益ಠლ
South Australia
VR S2 Exec
I thought 6psi was a safe boost for a stock engine.. or was that for the 8's? :\
|<untzie
Pontiac Grand Prix Turbo
i run 20psi on a stock buick 3.8L, these things take boost for a very long time without issues... this was on 19.5 psi, stock heads and head gaskets, cam is a .574/.566 lift, turbocharged
http://i22.photobucket.com/albums/b342/ku ntzie_86/583.jpg (remove spaces)
ajvx01
North east Adelaide
308 vc
where you sourcing the sc from? and i've seen a few running 9psi safely stock..
