what ohm am i running?
HoLDenGuY
40
1994 VR Commordore
Hi guys i have a rockford fosgate t1001bd 1000 watt amplifer, im running 2 infinity 250watt rms subs from it.
I know usually mono amps just have one channel + and -, but this rockford amp is like a 4 channel amp and has 2 + - on it, one amp is connected to the first set of + and - and the other is connected to the other + and -. Anyone know what ohm its running at? hope that makes sense! thanks
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
2ohms......
craigvk
Banned
VK 5L Calais
If you have two subs and you connect one each to the +ve and -ve terminals then it's 2x 4ohm.
Tasmaniak
41
S.E. Melbourne
no, thats if you connect them in series. then you will have 8ohms. but when you connect them in parralel you get 2ohms.
craigvk
Banned
VK 5L Calais
Over here car speakers are 4 ohm types. If he had 2 +ve terminals and 2 -ve terminals and to each of them he connected a speaker, then there would be a 4 ohm load on each channel. Am I missing something here?
craigvk
Banned
VK 5L Calais
AFAIK the OP isn't running a mono amp looking at his post. If he was then yeah there would be a 2 ohm load if the 2 subs were wired in parallel.
HoLDenGuY
40
1994 VR Commordore
it is a mono amp but it has 2 + - just like a 4 channel amp
craigvk
Banned
VK 5L Calais
Hi HoLDenGuY,
It can't be a mono amp if it has two +ve and -ve terminals.
AFAIK mono amps are single channel? I am not familiar with your setup. Not sure what you mean. :confused:
craigvk
Banned
VK 5L Calais
Are you sure it isn't a 2 channel amp? If you connect each sub to each of the +ve and -ve terminals then it runs in two channel mode and therefor you have a 4 ohm load on each channel.
Genesis
40
VC SL/E Station Wagon
That model is a single channel amplifier.
Channels 1
Per channel power
CEA-2006 compliant
500 W x 1 @ 4 Ohms RMS
750 W x 1 @ 2 Ohms RMS
1000 W x 1 @ 1 Ohms RMS
Total power 1000 Watts
Bridgeable Master Sync
Power Sync
(bd-sync2)
Crossover LP 32-250Hz 24dB per Octave
Subsonic Filter 28Hz
Tone controls Bass Control
0 to 18 dB @ 35-70 Hz
Signal input Low level -
Quantity - 1
Type - RCA(pr)
Line output 1 RCA(pr)
Phase control 0/180 degrees
Power input Connector - Block
Wire gauge - 1/0 AWG
Speaker output Block
Power supply topology
Output topology
Display
Heatsink Type -Cast
Cooling -Fan Cooled
Protection
Remote control Included
Type - Wired
Controls - Bass
Class B/D
Marine use
Specifications
Stereo/Mix mono
Frequency response 20 to 300 Hz +/- .5 dB
Dimensions 2.6 X 12.8 X 18 (inches)
Source: http://www.mobileonesales.com/product_p/t1001bd.htm
