Thanks for the info,
Re: clearances I have a bit of a Frankenstein exhaust set up at the moment, OTR VE hsv headers, VF GTS midsection and an aftermarket set of mufflers.
I sounds good and is at a volume level that I like so I would probably just swap it over to a newer VE or VF and then just get a tune and be done with it.
The main thing now is if i spend money on new parts, wheels, suspension etc I want to make sure i can salvage them as considering the age of the car its probably not worth doing anything if at all. Plus i'm still deciding what to do with the transmission.
Transmission is series 1 6 speed (auto)
Symptoms of the issue is that there is a significant flare between 3rd and 4th, when accelerating from rolling (at around 10-20kph) the revs will build up freely and then jump into gear causing wheel spin / traction control. If you feather the gas you can prevent it but its still spooling up the revs constantly.
Other issue is in manual mode when changing down from 4th to 3rd there is a delay when engaging gear so it jerks abit, i can overcome this by blipping the throttle but its probably not good to do long term.
I got a transmission service done (at 200,000kms) and was advised the fluid smelt burnt, car ran well for a day or two but then the same transmission symptoms returned, I had another cleaning run done and reset and it was fine again for a few days but then same problems.
All of the transmission places I have spoken to have advised they could do the Tekum solenoids for about $1000 but this might not work so all advise to do a whole rebuild.
Best option at the moment is Craigs autos for around $4000, I got a quote from RVO in Melbourne for $2,800 but I have heard some dodgy stories so im abit weary of them.
Other option is to just live with it and use manual mode all the time but apparently the transmission will **** itself one day.
Cars probably worth $10,000 on a good day, really wondering if its worth spending over a 1/3 of the value in getting this fixed. Theres no other problems with the car though but maby considering the age and kms other stuff will start to go wrong, pumps etc.
Im waiting to see what this years tax return looks like then will decide what im going to do.
