Vs hsv manta
- Nov 7, 2012
- 340
- 6
- 18
- Age
- 40
- Location
- Mackay
- Vs hsv manta
18 is not unusual for low comp start. low comp more advance needed to fire (no idea what you have as I have not read). some cars need up to 25. forget holden 10 as you no longer have a holden 304. fyi whatever dissy says is what it starts at. Advance ( at idle or whatever ) only happens once ur motor is running - NOT at start.
btw, ur manifold pressures do not seem ok
Cheers mate thanks !!! It's a long way from been a Holden 304 now and the comp is low down at 8.47 !!
An manifold vacuum when idle is about -12
when driving at 2000RPM and back of no throttle it goes - 20
And just cruising it varies from -10 to - 2 depending on throttle
This is still running N/A for run in of 1000km the blower is not connected yet !!!
Does this seam right if not what do u think not should be ???
