Pretty sure vy's are 6"' front and rear! Depending on models, Please correct me if im wrong but Calais/HSV have Splits up front & 2 way 6" in the back doors. Calais/HSV also have 8" Subs in parcel shelf adding upto a 10 speaker system.....
6" indeed, though 6.5" will fit pretty easily. Most tweeters are 1" maybe 2" but they all fit, so when buying coaxials or component speakers 6" and 6.5" are both fine provided you don't mind cutting the speaker mount a little bit.
Heffany did that help at all? These two hit the nail on the head anyways, let us know what speakers you end up getting
i got told from a bloke at autobarn that 6.5 will fit but need to be shallow, but im not 100% sure so dont quote me haha
My factory vy and vs speakers have been 6", 6.5" ones fit if you make mdf baffles for them. There's heaps of depth in the doorcard, just space it off the door 2 or so 18mm mdf thicknesses
Agree. I put 6.5 splits in the front doors and 6.5 coaxials in the rear doors of my VY when I had it. Just use a spacer, either make them or buy them. They are pretty cheap. They add the benefit of giving your speakers something more rigid to hold them than the door metal. Also worth putting some kind of dampening pad in when you do it all.
my VY S II has 6" front and rear with tweeters in the front near the windshield corners from the factory. fitting 6.5" splits is very do-able but does require modification depending on how deep your new speakers are. Almost certain that you will require some modification to fit them correctly.
half being on this subject i have a vy ss and want to upgrade my stock system i was thinking of getting this. what do you's think? will this be a decent setup and ill get a good setup out of or is there anything im doing wrong or anyone would do different. any advice is greatly appreciated. Alpine Electronics of Australia - sub Alpine Electronics of Australia - back speakers http://www.alpine.com.au/showItem.php?item_id=224- front speakers Alpine PDX-5 5 Channel Car Amplifier | eBay - amp Pioneer - Error page headeck oh and being 6.5 ill be fine to fit in doors and get the cover back on? thanks
I thought I would just add to this out of interest to whoever is reading , it is now 2019 and this is what I reccomend myself I have a immaculate VY 5.7 litre Calais nice coulour Black it is all original an old man owned the car before me and took exceptional care of it , Anyway this is what I would do , get rid of the factory amp in the calais VY , put in a nice 5 channel amp with at least 400 watts at 2ohm as rear subs you can replace with much better 8inch subs I have seen some with 250watt rms at around $140 each so 2 of them $280 . see the calais subs are GAY at 50 watts it says on them and I doubt that’s even RMS , so rip them out buy some better 8inch subs , also the head unit take that out , the one that I bought it is a pioneer DVD/CD rear view camera capable with applecarplay with the Waze app on it it cost 2019 $439 on eBay . Then however the head unit of you you need to buy the fascia kit and steering control patch that’s like another $150 on eBay , Now the door speakers go with some high quality Sony or pioneer with crossover tweeters these sets are usually about $120 each so $240 for front and rear and as well I would probably use MDF board cutouts make some up as spacers for the door pods you can cut the plastic out though that stops them from going all the way in however the MDF board sounds more sensible . Also the speakers you want at least 60watt RMS to match what most 5 channel amps output to each speaker so a 5 channel amp roughly 4 x 60watt RMS , then the Subs at at 2 ohms x 2 you would get about 400watts . Now you could go bigger however the system I just explained is extremely powerfull. And I agree the calais factory setup is not worth pissing on So in summing it up in 2019. -$439 pioneer 2DIN head unit -$150 -steering wheel control patch Wiring harness and fascia kit -$240 for 2 x 250 watt 8 inch subs -$240 for front and rear quality speakers With crossover tweeters -$200 maybe for a 5 channel amp , I bought a JENSON 5 channel D Class people told me it would be Garbage however it’s very good -$80 for amp wiring kit and possibly new Speaker wire especially to subs And time if you do it yourself that’s a huge amount of work it’s is well worth doing don’t expect any help though in doing it in this selfish society unless you pay an audio shop however most audio shops are rough as guts , Now all together to get a decent system just for hardware $1300 , I know however that’s the price you have to pay and if you try being a cheapskate on it the job you do will be garbage , If you pay someone and don’t expect a quality job maybe $600 . I know how to install all this stuff I’m an Automotive technician . If you think there is a way to get a kick arse system cheaper you would be almost fooling yourself most people selling second hand you can go that way to save a little but make sure you get quality or quality that’s good enough through reading reviews etc . I won’t lie to any of you a decent system researching , installing etc is very hard and expensive and time consuming BUT WORTH THE END RESULT
@Mookie01 Its November 2019 and in my VY S II I just bought a few weeks ago I am getting an audio shop to put in a Sony XAV AX100, (touchscreen bluetooth double din head unit without CD player), 4 Rockford Fosgate 6" punch speakers, 1 for each door, and the steering wheel control kit and fascia kit, its costing $1075.
Price is over the top, personally I think Sony is crap and for speakers I would go splits up front and 2 ways in the back doors using 6.5" speakers, pioneer or kickers, My head unit I brought off ebay for 300 has it all with GPS built in gr8 unit no need to buy extras like steering wheel controls as it already built in. Eonon unit hasn't missed a beat for 5 years.
How's that? the headunit it $500, the speakers are $200 a pair, so $175 for labour, the price of labour is exorbitant, but it always is. Furthermore, the Sony head unit I have in my other car has been in it for 7 years and still works as good as the day it was installed.
Personal choice it comes down too, 500 that's 100 more than JB Hi-Fi is asking for, speaker well they are only 130 a pair online your being ripped off, I be buying online and just pay for installation, I suppose his charging 100 for the steering wheel harness module. Just trying to save u money. Ebay has the unit for 380.00
