what t peice do i need? help needed asap
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
1995 VS Commodore v6 ecotec
hey guys, ive spent months and months trying to get this bloody sandwitch adapter to work with the oil filter etc, but it hasnt worked, i cant afford a filter relocation kit at the mo so im gunna have to go for the t peice
heres the guestion
i want to mount a oil pressure and oil temp sender, what is the name/size of the t - peice that i need to buy?
(95 vs commodore, ecotech v6, 3.8 - incase you were wondering)
i need an answer asap so please any help would be brilliant!!
TUF UTE
Dave
adelaide
05 VZ SENATOR
i have one in stock. can do it for about 15 dollars.
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
sounds good to me!!
how much to send it to rotorua, NZ
how soon will it arrive??
TUF UTE
Dave
adelaide
05 VZ SENATOR
231-088 is the part number, its a 1/4 thread. VDO brand.
cheaper to get it in nz mate as postage will cost more than the t piece itself
hope thats been some help
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
cheers bro! thanks for that!!
if i was in aus id def be pickin it up off you!
thanks for your help!
TUF UTE
Dave
adelaide
05 VZ SENATOR
no worries mate. good luck with it :)
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
thanks again!
1 more question tho
obviously im only gunna have the aftermarket pressure and temp sender attached to the engine, what do i do with the old stock sender? and will the oil light be constantly on on the dash?
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
or new brian wave!
can i rewire it so the new aftermarket sender is wired not only to the oil pressure gauge but also to the stock oil pressure sender and thus the ecu and oil pressure light??
TUF UTE
Dave
adelaide
05 VZ SENATOR
get a t piece, put the factory sender in the top of it and put your aftermarket gauge line in teh side of it ...
search for my ute and u will see where i mounted my gauges
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
and what about the oil temp sender?
