hey mate yep I'm about to buy a kit through Mace and the locking tools , so you just locked the cams and done the chain switch over without rotating first to first stage then locking, removing rh bank chain and turning to stage 2 .
I have watched several videos for months and also have the hayes manual.
if you could look at this link and any advice or comments would be appreciated.
Those videos are a great source for reference,
Before you remove the old chains and lock the cams,
Rotate the crank gear so the markers line up at the 8 o’clock position, (Stage 2 Timing as per image below)
This lines up the dimple on the bottom sprocket to the dimple on the oil pump.
Then install the cam locks,
Depending which chain is stretched the most, you may need to jiggle either cam to install the cam locks, this can be achieved with a 19mm open spanner on the hex “on” the cams,
When the cam locks are installed,
You can proceed to removing the old chain tensioners, chains guides & chains from left to right. (looking at the front of the engine)
If you have compressed air on hand,
Give the oil supply holes to the tensioners a blast, keep in mind, it may spray oil from other oil ports,
At this point you can replace the oil pump if that is part of your project,
(And is advisable, you will see why)
Clean the front cam cover, and contact surfaces ready for refitting.
Install new crank sprocket,
Then the re-assemble is straight forward,
Starting from the right side (looking at the front of the motor)
And making sure you align ALL the markings up,
(Hint: I used a fluorescent marker on the gears/sprockets and chains)
And mine went back together perfectly both times.
Again, you may need to jiggle a cam into position for one of the chains to sit correctly on the sprocket/s.
Remembering to remove ALL the pins when your satisfied ALL the marking are in the correct position,
Double check the markings, Then remove the Cam locks.
"You DO NOT need to rotate the CAMS between Stage 1 and Stage 2 when you are using Cam Locks"
You First set it up on Stage 2 and Leave it there till your ready to remove the Cam Locks at the end,
As per my 3rd line comment up top.
*Important* “Torque ALL the bolts to Spec” not over Spec, not under Spec,
To the "Correct Spec" !
Hint: if you have an oil can, just give the new chains a drink, saves them running dry on start up.
And then install the water pump seal on the front cover with some RTV on it,
and enough RTV on the cam cover contact surfaces before you install the front cam cover,
Otherwise, the rest is straight forward.
But most importantly: Take your time, as you don't want to be doing it twice !!!
Side Note: Ice cream containers are a great item to use when pulling it down,
Place the items in them, with a bit of degreaser, and let things soak while working on it.
Good luck.
feedback is most welcome.
PS: Keep an eye on the 10mm sockets, as they seem to escape all the time !
