What Type Of Diff Do I Have????
brocksta05
37
somewhere NSW
2000 VT S2 Acclaim
Fitting higher diff gears will kill the acceleration, but will drop the engine revs slighly out on the highway at 100 km/h .. Most people fit slightly lower diff gears for better acceleration..
I think you've got it backwards there mate. Higher gears for example going from 3.07:1 to 3.46:1 will increase acceleration and will make it rev a little higher at 100. going with lower diff gears sacrifices acceleration but brings the revs down
brocksta05
37
somewhere NSW
2000 VT S2 Acclaim
I'm thinking of going 3.46:1 gears in LSD. Will a centre out of a VL diff fit in my IRS housing? cos that would be awesome cos I just happen to have a VL LSD diff from my calais.
Cashman_309
VTII Calais
Wont fit. Live Axle diffs are very different to IRS.
Jack the car up, get under it and have a look to see what you're getting into.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
People say "higher" when in fact they mean "taller". A higher ratio, EG the numbers are bigger, mean shorter gears, or better acceleration. Lower ratio, EG the numbers are smaller, mean taller gears, or better top end.
Tomato tomarto, we all know what Brett means.
Brett_jjj
Tamworth NSW
vs commodore
Its not backwards at all. A diff with a 3.08:1 ratio, is higher(taller) than a diff ratio thats 3.46:1 . The higher this number is, the lower the gear ratio will be..A lot of young blokes always seem to get this ass about face.
Take the gear cluster on a 10 speed bike for instance. The smallest sprocket (which has the least number of teeth) is a higher or taller gear than the largest sprocket (that has the most teeth). So the higher the number( of teeth), the lower the gear ratio,same as a diff.
Cashman_309
VTII Calais
3.08 parts to 1 vs 3.46 parts to 1... ratio seems higher to me, That's how I like to say it, and that's how most people understand it.
I stand by my original post.
Brett_jjj
Tamworth NSW
vs commodore
Ive never heard many people say it like that except for a few young blokes who dont seem to know any better. Thats why I posted up and said something so the guy doesnt end up with higher diff gears instead of lower.. Even car magazines like street machine word it like, "this guy has removed the standard 3.08 diff gears and has fitted lower ratio 4.11 diff gears" Ive got heaps of car books here that all say it the same way I do, and the diff specialists Ive dealt with over the years also say it the same way as I do, and I think theyd know if anyone knows.. Just because the number is higher does not mean the gearing is higher, it means the opposite.
WazzaVN
Wazza VN
VZ 6ltr ute, VP Calais and HJ Prem
It's true. Just like lower ratio gearboxes and all. I just say shorter to save confusion.
Don't get 3.45's they suck and you'll be dissapainted. Atleast get 3.7's. I've got 3.7's in my vp and sometimes wish I had 3.9's. And I've got 3.9's in my ss and wish I had 4.11's haha! M78 LSD centres are good too. Better than m80 anyway. There's a couple of online diff stores that sell tight centres for about 250 - $300 if you want to source One yourself. Has to be IRS though. Live axle centre won't go in.
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Tch tch tch.
Any BW78 differential centre will fit into the BW78 IRS differential housing.
Not a hard job to change centres. Just need to know what you are doing.
