What tyre pressure?
M
matty193
Guest
Hey everyone, just wondering what the optimal type pressure should be for a set of Nankang 18" 235/40.
On the tyre it says do not inflate above 44psi, but this seems a bit on the high side, considering the stock tyres recommendation is for 28 front and 34 rear.
Any suggestions? Thanks!
volotre
47
As often as possible
I run 36 - 38 psi on 235/50's, I find any higher is a bit too harsha ride. It is a family taxi tho'!
Jamie_87
2003 BA XR6
im running 38-40psi on my 18's, i was running 35psi before and it felt sloppy, now since i put it up, handles loads better and rides better over bumps. feels more solid if u get what i mean
holden007
VRII
Subaru Liberty
so 30psi for 17' tyres is low? mine were pumped to 40psi at the tyre place, the ride was very rough, dropped to 30psi and smooth.
jNINE
Bris
forums.justcommodores.com.au
I have a 'couple'
It is a little on the low side... I run 36 front, 34 rear and can tell if they get down to around 30 as the handling changes and it starts understeering etc. If they are too low you might find they wear on the outside edges too.
VKStevo
35
VP Exec
38-40 seems very high to me, i put 34 in my 17's
Torquen
Boost FTW
34
Perth, WA
450+ HP FORD XR6T
myn are 34 psi with 15's
Jamie_87
2003 BA XR6
lower profile tyres need a higher pressure than the higher profile tyres as there is less rubber to roll and protect rims from potholes, the more pressure u have the less rol and less chance of buckleing a rim on potholes,
like i allready have because i had my pressure too low:bang:
ChRiDDa
N/A
VE SS-Z Sportwagon
^^ exactly!! i run 40 pound in my 18s, 38 in my old mans car, which has 17s
