What's that small hose on top on vz motor
Frog201
hi all
Right on top of the motor there this small hose (you don't even have to take the plastic cover off to see it)
well mine has split and want to know what's it called so i can order a new one
THUNDERVZ
sydney
vz thunder s ute
Get ready for a shock when you pay ....
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
It runs from the top of the passenger side rocker cover to the manifold. Order a new inlet manifold gasket while you're there because the manifold needs to come off. Maybe a good time to do plugs aswell.
commodore665
expat Saffa
54
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
Good grief GM don't make things easy do they :spew:
Sabbath'
Redblock Jesus
6 bolts for the manifold an a couple of hoses, shouldnt take more than 20 minute max. Including the spark plugs.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Save yourself some cash and wrap it with black electrical tape.
Bilby
Tamworth
VZ SV6
I'm not a mechanic, But I would say that this hose is just part of the emission system and it simply to return the gasses back into the motor, so as Ricey said, wrap it with some tape. However if I'm wrong, than one of the mechanics no doubt will put me right.
morphix
Cardiff, NSW
2004 VZ SV6 5-Speed Auto
Its the Position Crank Ventilation hose, which is part of the emission system, this crack can cause a horrible idle and performance issues where the car nearly stalls, due to vacuum leak.
From Holden, the whole hose piece costs $85, when i got it 8-12 months ago.
Some people have gone and just replaced the plastic elbow, but tape works, try self-amalgamating tape, this worked fine for me till i got the hose replaced.
RiCeY
Australia
*Positive Crankcase Ventilation
Stewlz
07 VE SSV ute M6
Not entirely true morph, it's not the positive crankcase ventilation system , that hose runs to a solenoid on the back of the passanger valve cover which vents fuel tank fumes. 100% agree with splits in it causing bad idle through loss of vac, definatly just tape it up
