304 whats the name of the sensor? passenger side of bananas
GTP 85
291 hp @ the wheels
35
Murray Bridge S.A
MY04 WRX, VS SSenator & VS V6 track weapon
Can someone tell me what is the name of the sensor that screws into the bananas on the passenger side of the engine? its in amongst the injectors.
I pulled that sensor out to check its condition and it was caked in oily crustyness. i just replaced it with another one i had sitting on the shelf. Would this sensor being clogged up cause the hunting idle issues?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
will be the intake air temp sensor with a little cage on the end with a funny variable resistor down inside the cage i pull them out and hit them with carby cleaner can make a little difference in the temp the ecu sees
