Wheel fitment
romez
2012 SV6
Hi guys I have a vp calais that I will be taking to the track late this year chasing times. I want to sort out the wheels in the next couple of weeks with a set of centreline pros. I want to know exactly what size wheels guys have fitted with no mods. (IRS) please don't reply if you are not sure o Lu if you actually have had a set before cheers
mr calais 5.0
victoria
vy s 2003
Are you looking for stock sizes or 18's and what rubber are you using?
_R_J_K_
Zenki S14
To make any fair comparison between wheels you'll also need the width and offset.
romez
2012 SV6
Looking at 15s by 8.5 ?
ducker85
Narnia
09 VE clubbie R8
do you the bad new or the bad news first?
they only make Chev stud patterns 120.6x5 or (5x4 3/4 inch I believe) and Holden uses 120x5 so you WILL snap studs as the wont fit properly
I have measured a set of VP Senators rims 17x8 30P offset (these suit IRS which you have) and the need 6 1/4 inch back space which no US wheel company's like centerline offer.
you will need 120x5 stud pattern with like 15x8.5, 6 1/4 or 6 1/2 back space so good luck
