When I hit the boot lid button
TomJones
2011 Holden Commodore SV6 Series 2 Sedan Automatic
Well hello from rainy Melbourne northern suburbs..
when hitting the boot release button on the remote or in the glovebox .. if the shockers are like new.. should the lid just open up completely ? I've been missing out cause it don't do that at all.
Should I change the shockers?
Help me sleep better tonight please :)
Vin999
SA
VSedanS
I heard they are doing these checks with problem carowner's boots at albert park tonight. U might wanna check it out ;)
TomJones
lol true, lots of imagination .. we what could have done lol
mechanic
Australia
Commodore
Nah, I’ve never seen this happen. it pops but stays closed. Once you move the lid up a bit the hinge geometry allows the struts to push and hold open.
Trevor loves holden.
vs commodore
Hello from the wet western suburbs, the struts can lift it completely if you change the lifting points, do you have a boot spoiler, if so get the ones for boot lid spoilers if not get them anyway it might be just enough to make it lift, u know how physics works so if you want it to pop open you need longer struts and move the ball back further. Be nice if they made pump up struts to up the pressure.
DavesSV6Tonner
Australia
VZ S V6 Cab & Chassis
when hitting the boot release button on the remote or in the glovebox should the lid just open up completely ?
No.
Fu Manchu
WA.
Using stronger struts for models with accessories will not push the boot lid up when opening.
They are designed to make lifting the lid easier. Lift assist. That’s all.
I have the struts for a heavier boot lid.
Did this because the lid liner is also insulated (I added it).
Even with no boot lid trim fitted, the lid does not lift or pop up itself.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
You dont want the boot lid to pop all the way up.
Just imagine what might happen if it got caught by a gust of tail wind whilst it was opening...
vs commodore
You can get spring loaded door poppers, they use them on hatch backs to pop them open. Its the first stage of helping the strut to lift once they get going in motion and if they are good they will lift, I got a pair of spoiler struts before adding the spoiler and it was opening up on its own but only on hot days.
426Cuda
SUBLIME!
Wagga Wagga
VF Redline Sedan - A6 Spitfire MSE...
They do open in the VF. Even with the big spoiler mine still open several inches.
