When VN S2 Start?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pro_gmh, Sep 10, 2006.
  1. pro_gmh
    pro_gmh Active Member
    SA, Mount Gambier
    VL
    after a quik search, couldnt find a clear answere. when did vn s2 start? also did the vp use the same gbox as vr? and did vr and did vr use the same gbox as vs? getrag??
  2. 1vngal
    1vngal New Member
    North Tassie
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    I'm pretty sure the Series II started around May?! 1991. I think it was May, I'm not sure bout VP and VR using the same gearbox, But I'm positive they did. And the VS had a different gearbox to the VR.
  3. Nikkojoe
    Nikkojoe Member
    AE86, VE M6 UTE, Toyota 86
    VN S2 started in like August/September 1990, VP followed a year later. VP does not use the same gearbox as a VR. VR is computer controlled whereas VN-VP is kickdown cable controlled. VR/VS had the same box, 4L60-E (E for electronic controlled). That's for auto. For manual, VN-VS S1 used a Borg Warner T5 for the 5spd V6, and VS S2 used a 5spd Getrag.
    For more info, visit http://www.users.on.net/~%20nweber/commodore/
    pro_gmh likes this.
  4. pro_gmh
    SA, Mount Gambier
    VL
    thanks for clearin that up for me ;)
  5. 1vngal
    1vngal New Member
    North Tassie
    I thought the 1990 vn was classed as the "series 1.5" Meh, oh well....At least i know i was wrong now!
  6. pro_gmh
    SA, Mount Gambier
    VL
    S1.5?? what difference would there have been with that between 1 and 2?
  7. Nikkojoe
    Nikkojoe Member
    Nar, my vn is a Feb 1990 and its still a series 1. They were out for a very short time. Im sure it was around March/April when the S1.5 (twin water bottle design).
    Basically S1 had the basic fwd buick motor converted to RWD. This ment that the thermostat was at the rear of the engine and had no radiator cap and overflow bottle. However, it did have a surge tank which you fill the water from. There were also various other internal differences.
    Series 1.5 had an overflow bottle aswell as the surge tank and some slightly modified internal components, although remained pretty much like the S1
    S2 is pretty much the same from VN S2-VR (Thermostat at the front of the engine, revised coil packs, bellmouth in thottlebody elbow, revised fuel rail are just some of the exterior changes). Only minor changes here and there from VNS2 to VR
  8. pro_gmh
    SA, Mount Gambier
    VL
    My mates vn is was made feb '90
