Heffer_Slayer
basicly u gotta use ur ears and listen 4 distortion. 2 set the gains turn the gains all the way down fully, fade all ur sound into the 2 front speakers using the head unit, then turn the speaker volume on the head unit up fully. then from there using ur front gain control on the amp slowly turn it up until u hear the speakers faintly distort, then after uve found that spot where it distorts turn ur gain back down a lil.
doin this will allow u 2 turn ur head units volume right up and also will protect ur speakers if some clown decides 2 jump in n crank ur speakers as loud as they can go with out knowing at wat ur volume limits r.
if u still need 2 change some settings on ur head unit 2 make it sound better do so and then adjust ur gains 2 suit again, then adjust ur rears the same way.
Thanks alot mate! That was really helpful.
Would you recommend i run the speakers at 130wrms or 50wrms?
All it does it makes it louder doesn't it?
Also does the same principle apply to a sub?
Seems kinda hard to know how to adjust the gains for that lol, i guess until the bass distorts?
