What manual is that drawing from? I think it has a mistake. The pipe nearest the drain is the breather hose. It is shown as a small hose stuffed inside a bigger hose, which is correct, but is labelled fuel feed. The inboard of the 3 pipes goes to the fuel filter, and is therefore goes to the pump. The middle pipe is the return hose - that one is correct. So two labels are mixed up.The attached diagram should help:
thanks mate. diagram was just what i needed. cheers.The attached diagram should help:
