Where the ECU in a VY SS
Psycoss
Cornubia, Australia
VZ Senator
Hi,
I am going to get a mafless tune done, but need to take my ecu out first.
Can any tell and show me where it is?
Baldric
The BOSS
42
VE GTS M6
Hi,
no you dont. you use a obdII connecto to plug under the drivers kick panel
Skooby
VY II SS
Maybe he is getting a mail order done?
Get Oztrack to do it :dance:
Baldric
The BOSS
42
VE GTS M6
my applogies :D (open bonnet)
if its a 5.7 ltr its on passanger side chassis rail between headers and chassis (will have a black cover over it (10mm bolts are holding it on)
if it's a 6ltr its on passanger side strut area
minux
Infidel Bear
Hi,
OP, you will need to remove coolant tank, slide up the piece of wood covered in some metal thing below where the coolant tank was beside the headers. Release the electrical plugs, then you have to release pins that slot the ECU in. There is no bolts to undo, so not sure what the above is saying 2 10mm bolts for,
