Where to buy vn series 1 crank adapter?
Menace38L
Cairns, North Qld
Vn Calais
where and how much would it cost for an adaptor? its the adaptor to convert series 1 auto to manual? is ther anything else i need to get for this conversion aparts from all the manual bits??
rickybobby
shake 'n' bake
MEL
VR V6 T5, VR V8 T5, VS L67 statto, VY V6
NPreston
Victoria Point
VC
Buy a second hand manual engine would be better than the adapter probably cheaper as well.
383 hatch
39
Cowes, Phillip Island
What makes you say that? I used one many years ago, never had a problem with it, was fantastic. Granted though, that was back when VN V6's were actually worth more than a box of beer....Probably not worth spending the money now.
NPreston
Victoria Point
VC
Not a fan of the adapter, adds weight to the flywheel and I assume the OP is wanting to do the conversion for performance reasons. Reckon you would buy a VN V6 manual in good running order for less than the cost of the adapter, flywheel etc. I think the last part of your post answers your question.
Menace38L
Cairns, North Qld
Vn Calais
i jus want a 5 speed man got box and series 1 flywheel and few of the other bits for the conversion? jus need a tailshaft and starter motor ithink? and engine still good? y get a thrashed manual engine?
383 hatch
39
Adds weight? Hold on, it turns an auto crank into exactly the same dimensions as a manual crank, so whatever weight the adaptor adds, a manual crank would be the same....Think about it.
Also, if you buy a manual conversion, it will come with a flywheel so the only extra cost is the adaptor itself.
