Where to get HSV front rotors?
lockmac
Hi.
Does anyone know the best place to get some HSV front rotors? Not sure of the size, I think they are either 330 or 343. Need some for a roady and they arent cheap!
Holden want something like 300 each or something so am just hoping I can find a 2nd hand pair. Ebay doesnt seem to have a lot..
Troy5L
building a lemon
Mornington peninsula
Gu patrol td42
check repco, they would most likely have them, and they will probably be cheaper than holden
SIG-054
Y-Series Senator Signature
Get some off GSL Rallysport, around the $440pr
Edit, that would be the 330x32mm
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
Firstly you need to know which size you need as there is a big difference in price between 330x28, 330x32 or 343x32.
What car are they for and what calipers do you have fitted
330x28, VN-VS HSV (VN/VP are hub style and VR/VS are hat style).
330x32, VT-VZ HSV with 2 piston caliper in red or prussion blue, similar in look to the stock caliper.
343x32, VT-VZ HSV performance brake up grade, Harrop 4 piston calipers.
minux
2017 SSV Redline
As Surfwagon said, what size exactly?
I switched my piece of **** HSV over to EBC rotors, much nicer than the crap that moves with HSV, much cheaper also.
gslrallysport
VZ AWD One Tonner
As has been said, you'll need to know exactly what size off what model.
Johnsy
C/Town
VF SS Wagon & VF SV6 Ute
Just your rotors or your calipers as well ?
I find the rotors in the VE's are a lot better than VY-VZ Hsv's
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
