Where to mount v6 turbo water lines?? And oil return?
VS-S-PACK
30
Melbourne, BALWYN
VT S 5 SPEED MANUAL
Hey guys! im building a turbo set up and the end date to soon to come :D Just need to figure out where i can tap in my water lines for my turbonetics turbo and where i can return my oil lines? i have a T piece from the oil pressor sensor so thats all good but where can i return the oil without drilling into the sump?
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Straight down the dipstick tube.
And tee in off the heater lines for coolant.
tml678
2017 HSV30 Senator, 2002 Corolla..
CamdVt6
33
BurnCity Vic
Vt Calais 6
Hahaha ahhhh **** ‍♂️
You know any alternative for oil return besides tapping sump?
BowTie
Jindabyne
Vr vt
Can't remember what they're called but I have seen oil in/out aux circuits that go between the oil filter and block. Bolt on, removable and look ok.
For oil coolers and turbos.
Someone here will know what they are called. I can only remember what they look like and where they fit.
_R_J_K_
Zenki S14
Sandwich plates and filter blocks. The blocks are okay for turbo feeds and oil coolers and remote filters but they're not an oil return.
BowTie
Jindabyne
Vr vt
OK. I thought they had a return.
Thanks bloke.
_R_J_K_
Zenki S14
There's an oil inlet and outlet to the filter, but post that the oil then runs to the rest of the engine's oil galleries which means you'll be feeding hot turbo oil back into the engine - oil is responsible for a decent amount of cooling for most turbos, and then there are the oil cooled ones. The other problem is that that both the inlet and outlet are equally pressurized as opposed to a normal return where the oil just kind of falls out of the turbo into the sump.
