where to put car stands
.Holdon.
'01 VU Ute, Manual 5.7
you know how your ment to put car stands under your car when your going to be working under it for a while. well where do you put them? i'm using the jack points to jack the car up and from there where do the car stands go?
cheers
eurekamad94
street kiddo
qld
kitted, tuned, sick pantha VS
on the rails - 2 sqaure steel bits running right under the car
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
That's where I put them also and I use a bit a bit of wood in between to prevent any damage.
For the rear I use the big bracket where the crossmember is bolted to the body, using a piece of timber again.
MSE089
Black 6sp S2 VT SS
anyone got a pic of where to place jack stands on a vt?
Front and back?
bogan_vk
australia
commodore
i also put them under the chassis rails but i also put a couple of spare wheels under the edge of the car for safetys sake in case the car drops for some reason
jazza15
Jarryd
Eltham North, VIC
1999 VT II S
I'm gunna do a how to on this when I get around to it.
Already uploaded the pics onto photobucket, so will soon do a how to on jacking up and putting your car on stands.
Figured it would be a good starting point for those wanting to get into diy work on their car, but don't know where to start.
Will also be chucking up a setup of how i bleed my brakes for those interested.
vxcalais_01
VX Calais 3.8
jazza, that would be great, i have asked this many times, to the point i have been put off working under the car. THe car book and manuals shows a underside with 4 large dots, could be anywhere ??!!
MSE089
Black 6sp S2 VT SS
Jazza that would be awesome, Ive been looking for something like that.
Also bleeding the brakes would be the same as bleeding the clutch? Maybe put up a how-to on bleeding the clutch too?
Thanks mate
jazza15
Jarryd
Eltham North, VIC
1999 VT II S
It's up in the How-to section now.
I will be improving it in the coming weeks, so it should become a good starting point for all you starting out DIYer's out there.
