antis0cial
Hi just need some help choosing an AMP, not sure what all the ratings mean to be honest not sure if I need to be looking at the 4 Ohms or 2 Ohms rating in order for the amp to be running my 4 speakers.
They amps I have narrowed it down to are the following;
MB Quart Premium PAB 4100
MB Quart Premium PAB 4100 - 4-Channel Amplifier • MOSFET power supply • S/N Ratio: >95 dB • 24 dB subsonic filter - , Car Amplifiers, Multi-channel Amps - Sonic Electronix
Product Description:
* 4-Channel Amplifier
* Focused mass aluminium heat sink
* RMS Power Rating:
o 4 ohms: 100 watts x 4 chan.
o 2 ohms: 150 watts x 4 chan.
o Bridged, 4 ohms: 300 watts x 2 chan.
* MOSFET power supply
* Ultra-flexible and variable adjustable active crossover network
* Vario bass equalizer circuit up to +18 dB
* 24 dB subsonic filter
* Full range preamp outputs for easy daisy chaining of additional amplifiers
* MB QUART-Logo with illuminated red rectangle
* Wire concealing detachable end panels
* Frequency Response (-3 dB) : 10 Hz - 30 kHz
* Damping Factor: 200
* Signal To Noise Ratio: >95 dB
* THD: 0.05%
* Channel Separation: >70 dB
* Input Signal: 0.2 - 6.0 V
* Crossover S/W: LP.BP/Full/HP
* Variable Hi-pass / Subsonic Filter: 10 ~ 150 Hz
* Variable Low-Pass (mono 24 dB): 30 ~ 150 Hz Full range
* Bass Boost at 45 Hz: 1 ~ 9 dB
* Dimensions: 18" L x 10.4" W x 2.25" H
* 1-year Sonic Electronix warranty
Amplifier Specifications:
* Amplifier Class AB
* Number of Channels 4
* RMS Power (4 ohms) 100 watts x 4 channels
* RMS Power (2 ohms) 150 watts x 4 channels
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power 300 watts x 2 channels
* Peak Power Output N/A
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged 4 ohms
* THD at Rated RMS Power 0.05%
* Speaker Level Inputs No
* Preamp Outputs Yes - 1 pair
* Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
* High-Pass Crossover Frequency 10 - 150 Hz
* Low-Pass Crossover Frequency 30 - 150 Hz
* Subsonic Filter N/A
* Signal-to-Noise Ratio 95 dB
* Channel Separation 70 dB
* Bass Boost 0 - 9 dB
* Bass/Gain Remote Yes
* Fan Cooled No
* Fuse Rating 50A x 2
Now my other amp choice;
Response Car Amp 4x100WRMS
Jaycar Electronics
Specifications:
Power / channel @ 4ohm 14.4V: 130WRMS x 4
Power / channel @ 2ohm 14.4V: 190WRMS x 4
Power / bridged @ 4ohm 14.4V: 380WRMS x 2
Signal/Noise ratio: >90dB
Input sensitivity: 200mV to 5V
Low pass filter: 50 - 500Hz @ 12dB/octave
High pass filter: 50 - 500Hz @ 12dB/octave
Pass thru RCA: Yes
Dimensions: 400(L) x 258(W) x 50mm(D)
Price doesnt matter, They Jaycar is $299 and the MB Quart AMP Retails for $999 but I can get it from that site for $380 AUD delivered
I need them to power the following speakers;
HERTZ HSK165
HSK 165 - High-Energy - Hertz - audison
Rockford Fosgate T1693C 6x9" 3-Way Coaxial Speakers
Rockford Fosgate® - T1693C
Configuration 3-Way Full-Range
Midrange Diameter 6"x9"
Midrange Depth 3"
Tweeter Diameter .5"
Tweeter Depth n/a
Frequency Response 40Hz - 22kHz
Power Handling 110 Watts RMS
220 Watts Max
Crossover High-Pass (HP): 12dB
Sensitivity 90dB @ 1 watt/1 meter
Grilles Included Yes
Mounting Hardware Yes
Shipping Weight 9.9 Lbs.
(4.5 Kg.)
I am going to be using a JVC KD-AVX11 Head unit with a CAT10 for the VX
steering wheel controls.
Well would appreciate everyones help and suggestion as I am looking at spending from 250-400 on a 4 channel AMP to power these speakers. And really like the MB Quart but not sure on how good there AMPS are.
Thanks guys.
anti:thumbsup:
* RMS Power Rating:
* THD: 0.05%
* Fan Cooled No
Jaycar Electronics
Specifications:
Pass thru RCA: Yes
HERTZ HSK165
Midrange Depth 3"
Tweeter Depth n/a
220 Watts Max
(4.5 Kg.)
Thanks guys.
anti:thumbsup:
