which auto in a vr
tenggo
Vs Commodore, Vr Acclaim
Hi there, which auto goes in a 1994 vr v6 acclaim. I thought it was a 4l60e, or is it a t700.
ephect
Donating Member
VS Acclaim V6
yeap its the 4L60e and the model of trans you should be after is 4hdd or 5hdd.
4hdd = first letter being the year it was made ie.1994
tenggo
i thought so, cheers for that. I have a guy trying to sell me a t700 saying it will fit into the vr, can they work? i thought they were for vn vp .
ephect
Donating Member
VS Acclaim V6
yea the t700 is for vn/p, which is cable operated so short answer, no. not without screwing round
the 4L60e e being for electronic, which is all controlled by ur ECU and it'll throw a hissy fit logging codes.
stick with with whats made for it and u shouldnt have any dramas :thumbsup:
tenggo
Thanks a heap, just saved me buying the wrong one...
tenggo
Although the guy selling it reckons it is an electronic one... does this make any sense?
ephect
Donating Member
VS Acclaim V6
no probs ;)
ephect
Donating Member
VS Acclaim V6
technically the VP & VQ got the 4L60 which is cable operated and the VR-VS got the 4L60e.
if it has anything like 4hdd or 3hdd on it, that denotes the year it was manufactured. get that number off it if you can. that will tell you the year then we can narrow it down whether its electronic or not
CALAIS 6
snowballing
34
Adelaide,Tea Tree Gully
98 Triton mini truck
i have a question regarding this too i also have a 94 vr, Trans has 4hdd but its stuffed and i can get a hold off a 5hdd are they the same no diff??? just chuck it in and all plugs and stuff same???
cheers
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
cheers
Like ephect says 3HDD or 4HDD are the correct ones - I'm not sure but I think some 5HDDs may fit as the VR was still being made in early '95. The sure test is whether the plugs are exactly the same.
Question for ephect: - what is a "hissy fit"???
