which is a better motor ecotec or buick
htmunro350
SA
VP commodore,ht monaro
need peoples thoughts on motors which is better
Kiddo
You're serious bro?!
Mitsubishi Colt
Better in what regard? What do you plan on doing with it?
Need more info mate.
htmunro350
SA
whats the perfered motor to do up no drag racer but to have fun with for a v6 ive got a buick just interested in easy ways to get it up and moving without big bucks
hi_ryder
Donating Member
Pascoe Vale South, MEL
twin turbo on 40 psi...
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
This is a trick question?
Sent from here, so you can read it there. via iPhone.
htmunro350
SA
i kno extractors ive never mucked around with these types of motors before mainly built chev motors thats why im asking a lad up the road said put a chip in it this is stock standard so some budget help would be good
ephect
Donating Member
VS Acclaim V6
All depends on the car ur talking about. Vn-R U it has the Buick, so converting to ecotec is possible, but the vs-by has the ecotec and U can't drop a Buick in due to EPA.
So it comes down to the model of car U like and what engine is available and the year the car was made..
htmunro350
SA
well got a vp with a buick motor in it stock any i dears ?
stockies
Bannana
S/E Suburbs
G6E Turbo
Yeah, the Buick is easier to service and pull apart. The Buick in the VN update and onwards. You don't want a series 1 VN Buick motor.
How's that?
Jxfwsf
Aus
commodore
for buick, a vr engine is the best option, stock has higher comp ratiio and a few other internal improvements over the vn-vp buick
if going for FI then a buick has stronger bottom end and a vn-vp with lower compression would be the pick
ecotec if your staying na would be a good basis but is a bit of stuffing around changing exhaust and mating the earlier auto trans as the bottom brace from the bell housing to block differs....also these are generally lower km engines
Either v6 by nature produce their power down low, although the ecotec revs a little bit harder it's still not a good idea to rev either engine high, the split big end journals are a weak point on the crank and there's no way to change it.... higher than 6000-6500 rpm on a stock engine to often will end with something in the bottom end breaking, if money isn't an option you could import an aftermarket alloy block with 4" bore, stroker kit and turbo/super charge it to build a 1000 hp monster but it'd work out cheaper to simply drop and LSx engine in there....
At the end of the day it all comes down to what you want to do with it, both cost about the same to rebuild and they cost more than a 304 to reco......
